A trick used to remove it from a 2 stroke barrel is to use pool acid and rinse quickly.
It removes the aluminum and when rinsed quickly doesn't harm the barrel.
Use rubber gloves for sure. . .............lm
jensey wrote:Hi,
Why do you think deep grooves should be seen with a seizure ? I certainly see evidence of a seizure in multiple spots, but it's hard to tell if this is a full seizure caused by oil / heat issue's or by humidity / fuel issue's (water / fuel in the oil). For sure a re bore required,
Please make some pictures of the piston belonging to this cylinder,
[/quote]
