1st time building anything.
Working on the clutch today, not quite sure what the problem is...and I haven't run into anything obvious yet...
There's no adjusting it, one way it slips and then adjust it tighter and it wont go into gear and it also gets really tight and wants to walk away from me when it gets hot. I'm at a loss any idea what the problem could be?
Well I always use 30w non-detergent oils. I figured that's what it says on the crank case so that's what I go with. But if anyone had any input about the oil I should use.Tango911 wrote:u might want to ask around about what type of oil to use, the modern oils are more slippery and may be causing yoru clutch to slip. just a thought.
