Dianne's C77
sarals
Post by sarals » Fri Aug 28, 2015 1:27 pm
DianneB wrote:Yea, and now it is the carb that's driving me nuts! (Will post about it in the carb section.)
LM can help you there. He's The Wizard.
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
DianneB
Post by DianneB » Sun Aug 30, 2015 7:58 pm
Made huge progress with the carburetor issues today - the bike now "gets up and goes"! Still some adjusting to do but definitely runnable!
sarals
Post by sarals » Fri Sep 04, 2015 3:34 pm
DianneB wrote:Made huge progress with the carburetor issues today - the bike now "gets up and goes"! Still some adjusting to do but definitely runnable!
1989 NT650 Hawk GT
DianneB
Post by DianneB » Sun Sep 06, 2015 5:52 pm
DianneB wrote:I also lost my neutral light when I did the overhaul so I have to trace that down as well - probably missed an electrical connection in the rush.
Tracked down the problem! The first one, as I was advised it probably would be, was the wire broken off the neutral switch - fixed that (after breaking the screws loose with a chisel!) Second problem was that the bulb keeps falling out of the little right angled boot and landing in the bottom of the headlight enclosure - fixed that (with a little contact cement!)
Also, in re-reading the carburetor section of the service manual, I figured out I was turning the "air screw" the wrong way to lean the low speed mixture! DUH!
Got the fuel tank back on after making a new fitting to install an after-market petcock, put the carb back together and put it back on and tested for leaks or seepage - none.
Don't know if I will put the right cover back on or wait until I get the starter clutch overhaul parts on Tuesday.....
DianneB
Post by DianneB » Mon Sep 07, 2015 3:53 pm
Since the Dream was almost buttoned up, I decided to put the right cover on and see how it runs.
HUGE IMPROVEMENT!
It has the occasional miss at mid-throttle but other than that it is running PDG (pretty damned good)! I may have to shield the lead for the electronic ignition to get rid of the miss 'cause it runs pretty close to the right spark plug lead and I still have to set the ignition timing at high RPM but we're getting close.
I need to track down why my tail and stop lamp have quit and the rear brake needs much adjustment but I am happy with where we are at this point.
Evening work: Adjusted rear brakes, repaired brake light circuit, repaired tail light circuit, and installed air filter. A good day!
DianneB
Post by DianneB » Sun Sep 13, 2015 8:07 pm
Installed the air cleaner and connector tube - PITA job! Wouldn't surprise me if people seldom changed the air filter because it is such a job (if you don't have tiny Oriental hands)!
The parts came in for the starter clutch so I overhauled that and gave the starter a 'major service'. Just need to get things back together and see what quits working next LOL! (Sometimes I think this bike is cursed ;) )
Hope to get it out for a test ride early this week and do the final mid-range tuning on the carb adjustments.
sarals
Post by sarals » Mon Sep 14, 2015 9:25 pm
Hurry up before it snows! :)
1989 NT650 Hawk GT
