                    Help! charging numbers all over the map!
				maia
First off I've checked all the threads.  Not charging originally so on the advice of forum members  changed up to modern rectifier and hooked it up as per snakeoils excellent diagram.  The voltages I get are the same as before I replaced the old rectifier and they are all over the map.  Fluctuating wildly by the second from 2 to 10 then back to 3 then 6 then maybe a 14, just nuts.  Checked resistance between generator wires. Between yellow and brown 2 ohms.  Between pink and brown 1.2 ohms between yellow and pink 2.8 ohms and none of them are grounding out.  Apart from a carb problem ( sooty plugs ) the bike fires right up and idles and accelerates just fine.  Any help woul be gratefully accepted.  Don't make me push it off a dock!
