PDO::ERRMODE_EXCEPTION, PDO::MYSQL_ATTR_INIT_COMMAND => "SET NAMES utf8mb4", ] ); // --- Fetch newest completed CA entry --- // Assumes h305_ca77_entries is either a view or table already filtered to "completed" rows $sql = " SELECT model_year, model, ADM_StateOrProvince, ADM_Country, condition_value, opinion_value_today FROM h305_ca77_entries ORDER BY submitdate DESC, id DESC LIMIT 1 "; $row = $pdo->query($sql)->fetch(PDO::FETCH_ASSOC); // --- Helpers for casing normalization (same pattern as CB / CL) --- $keepCaps = static function (string $w): bool { // Keep original word case if it's already an acronym (2+ caps) or has a digit return (bool)preg_match('/[A-Z]{2,}/', $w) || (bool)preg_match('/\d/', $w); }; $word = static function (?string $w) use ($keepCaps): string { if ($w === null || $w === '') { return ''; } // Respect hyphenated parts independently if (strpos($w, '-') !== false) { $parts = explode('-', $w); foreach ($parts as &$x) { $x = $keepCaps($x) ? $x : ucfirst(strtolower($x)); } return implode('-', $parts); } // Already looks like an acronym or has digits -> leave alone if ($keepCaps($w)) { return $w; } $dot = substr($w, -1) === '.'; $base = $dot ? substr($w, 0, -1) : $w; $done = ucfirst(strtolower($base)); return $dot ? ($done . '.') : $done; }; $titleCase = static function (?string $s) use ($word): string { if ($s === null) { return ''; } $s = trim($s); if ($s === '') { return ''; } $t = preg_split('/\s+/', $s) ?: []; foreach ($t as &$x) { $x = $word($x); } return trim(implode(' ', $t), ", "); }; // --- Build display line --- if (!$row) { $line = 'Latest Registry Entry: No completed entries found.'; } else { // Location: "WA, Australia" (skip empties, title-case each part) $region = $titleCase($row['ADM_StateOrProvince'] ?? ''); $country = $titleCase($row['ADM_Country'] ?? ''); $loc = trim( implode(', ', array_filter([$region, $country], static fn($v) => $v !== '')), ', ' ); // Normalize opinion_value_today using CL rules: // >=1000 => use as-is ($12500 => $12,500) // 100..999 => treat as dollars ($750 => $750) // 1..99 => treat as thousands (6 => $6,000) // otherwise => "Not Entered" $valFinal = 'Not Entered'; if (isset($row['opinion_value_today']) && $row['opinion_value_today'] !== '') { $n = (float)$row['opinion_value_today']; if ($n >= 1000) { $valFinal = '$' . number_format($n, 0); } elseif ($n >= 100) { $valFinal = '$' . number_format($n, 0); } elseif ($n > 0) { $valFinal = '$' . number_format($n * 1000, 0); } } // Condition decoding (same mapping you provided, with fallback) $condRaw = $row['condition_value'] ?? ''; $condMap = [ 'E' => 'Excellent', 'Exc' => 'Excellent', 'G' => 'Good', 'Goo' => 'Good', 'F' => 'Fair', 'P' => 'Poor', 'Par' => 'Parts Bike', 'R' => 'Restored', 'Res' => 'Restored', 'Rat' => 'Rat', ]; $condNice = $condMap[$condRaw] ?? ($condRaw !== '' ? $condRaw : 'Not Entered'); // Gracefully handle blanks so we don't get double-spaces like " Honda " $yr = isset($row['model_year']) ? trim((string)$row['model_year']) : ''; $model = isset($row['model']) ? trim((string)$row['model']) : ''; $bikePart = trim($yr . ' Honda ' . $model); $locPart = $loc !== '' ? (' — ' . $loc) : ''; $line = 'Latest Registry Entry: ' . $bikePart . $locPart . ' — Condition: ' . $condNice . ' — Value: ' . $valFinal; } // --- Build final HTML snippet (static, safe to INCLUDEPHP in phpBB) --- $builtTs = (new DateTime('now'))->format('Y-m-d H:i:s T'); // These first two lines are harmless in phpBB output: and $charset = ''; $stamp = ''; $htmlOut = $charset . "\n" . $stamp . "\n" . $line . "\n"; // --- Write atomically to shared include dir --- $jobDir = __DIR__; // wherever this script lives $includeDir = '/home/mstoic3/public_html/shared/include'; $includeTmp = $includeDir . '/latest_ca77.tmp'; $includeDst = $includeDir . '/latest_ca77.html'; $jsonPath = $jobDir . '/latest_ca77.json'; $logPath = $jobDir . '/logs/latest_ca77.log'; // reserved for future logging if (!is_dir($includeDir)) { if (!mkdir($includeDir, 0755, true) && !is_dir($includeDir)) { throw new RuntimeException("Failed to create include dir: $includeDir"); } } if (file_put_contents($includeTmp, $htmlOut, LOCK_EX) === false) { throw new RuntimeException('Failed to write temp include file'); } if (!rename($includeTmp, $includeDst)) { @unlink($includeTmp); throw new RuntimeException('Failed to move include into place'); } // --- Optional JSON breadcrumb for debugging / external consumption --- @file_put_contents( $jsonPath, json_encode( [ 'line' => $line, 'stamp' => $builtTs, 'ts' => date('c'), ], JSON_UNESCAPED_UNICODE ) ); // --- Done --- echo "OK\n"; exit(0); } catch (Throwable $e) { // Minimal error surface; log server-side, generic public output error_log("[generate_latest_ca77.php] " . $e->getMessage()); if (function_exists('http_response_code')) { @http_response_code(500); } echo "ERROR\n"; exit(1); }
The VIN
COBRARI
The VIN
Post by COBRARI » Sun Mar 21, 2010 12:07 pm
I just aquired a 1968 (?) 350 scrambler. It needs restoration. As far as I can tell it is only missing
the speedo and the side covers. It looks like it has no modifications and the engine is not seized.
I would like to know more information about the bike. I don't know where the VIN is located.
Any information would be greatly appreciated.
sotxbill
Post by sotxbill » Mon Mar 22, 2010 5:07 pm
just in front of the gas tank on the frame where the steering connects.
two cl77, three cb77, ca77, ca72, cb160, s65 and cb750
Help Stop Global Whinning
Its considered bad luck to be superstitious.
COBRARI
Post by COBRARI » Sun Mar 28, 2010 12:14 pm
Thanks for the info. I decided to not try to restore the bike. I sold it. My eyes are no good anymore.
Thats why I couldn't find the VIN.
Return to “Parts ID”
