Page 1 of 2
				Spark plug
				Posted: Thu Jan 19, 2017 9:33 pm
				by Newmanraia
				What is the correct spark plug for a 65 dream
				Re: Spark plug
				Posted: Fri Jan 20, 2017 8:13 am
				by Seadog
				Many use the NGK D8HA.  Do you have the handbook?
Newmanraia wrote:What is the correct spark plug for a 65 dream
				Posted: Fri Jan 20, 2017 6:08 pm
				by DJM
				Handbook says C or D7HW but back then the wide heat range plugs weren't around.
AS previous answer, either a D8HA or D8HS should be fine, certainly good enough to get you up and running and not likely to overheat through being too 'soft' and shouldn't foul if motor is in sound condition and the mixture / timing are both OK.
				Posted: Fri Jan 20, 2017 7:09 pm
				by LOUD MOUSE
				The early parts list book I have shows D-8H and I know for sure that there are other HONDA  manuals which show D-7X.
Go figure. .............lm
DJM wrote:Handbook says C or D7HW but back then the wide heat range plugs weren't around.
				Posted: Sat Jan 21, 2017 8:44 am
				by Seadog
				I'd never considered that the owner's manuals might have changed over the years.  I have no idea when mine was printed, but it recommends D6HW plugs for normal use and D8H for heavily stressed use.
				Posted: Sat Jan 21, 2017 8:48 am
				by LOUD MOUSE
				Look at the lower part of the rear page and you may find the year.
Could be I have my number off by one!*^*% ....................lm
Seadog wrote:I'd never considered that the owner's manuals might have changed over the years.  I have no idea when mine was printed, but it recommends D6HW plugs for normal use and D8H for heavily stressed use.
				Posted: Sat Jan 21, 2017 9:26 am
				by Seadog
				Looks like December 1965.
LOUD MOUSE wrote:Look at the lower part of the rear page and you may find the year.
