Page 2 of 3
Posted: Mon Oct 29, 2012 5:12 am
by FluteTears
Jlovvorn wrote:Thanks a ton guys!
Any idea where to source that clip?
Should I JB weld with the seal in place?
Or pop the seal out and JB it and then put the seal back in?
I think I would do it with the seal in place and try not to cover the top of the seal as you might need to replace the seal some day.
Posted: Mon Oct 29, 2012 11:35 am
by Jlovvorn
Thanks!
Gonna try it as soon as the hurricane dies down.
Posted: Mon Oct 29, 2012 1:52 pm
by jensey
Crankcases should be repaired when empty, dry and clean.
The best way to it is by welding, the second best is JB weld.
The same for cylinder heads, cylinders.
That's my opinion,
Posted: Mon Oct 29, 2012 4:01 pm
by Jlovvorn
Thanks Jensen.
But to my surprise it is NOT leaking out of the seal with a chunk missing.
Once I got it good and clean, I discovered it is leaking from behind the washer on the gear shift rod.
I assume there is a seal back behind the washer, but how do I get to it?
There seems to be a retaining ring holding the washer on, but it goes all the way around the rod, and I dont see how to remove it.
Thanks for all the help so far.
Posted: Mon Oct 29, 2012 4:08 pm
by G-Man
Take a look at this schematic.
http://www.cmsnl.com/honda-cb160-sport- ... ml#results
I think that you are looking at parts 21 and 7.
The seal is behind these.
Posted: Mon Oct 29, 2012 4:09 pm
by Jlovvorn
Ok, I see it now, #21 on the schematic.
But my clip seems to go around 360, and I dont see how to get it off.
http://honda.eastbaymotorsports.com/fic ... veh=132814
[/img]
Posted: Mon Oct 29, 2012 4:11 pm
by G-Man
You probably need to rotate the circlip until you see the gap.
