Please Help, Advice needed.. are the motors seized?
Offer $600 For Both?
Poll ended at Mon Jan 19, 2009 11:44 pm
Thats too much
0
No votes
Thats too little, he wont accept
3
75%
That sounds about right
1
25%
Not enough info
0
No votes
Total votes: 4
cbxmountainman
CB77
Post by cbxmountainman » Thu Oct 23, 2008 7:14 am
Both appear to be CBs as there is no down tube on the frames. CBs had the TOP engine mounting bolts whereas the CL only had BOTTOM mounting bolts. $600 is an excellent buy so you should jump on them before he gets away. Charlie
Re: CB77
Post by LOUD MOUSE » Thu Oct 23, 2008 10:19 am
The CL does have one top mounting bolt. .............lm
cbxmountainman wrote:Both appear to be CBs as there is no down tube on the frames. CBs had the TOP engine mounting bolts whereas the CL only had BOTTOM mounting bolts. $600 is an excellent buy so you should jump on them before he gets away. Charlie
RIDE IT DON'T HIDE IT!
cbxmountainman
CL Engine mounts
Post by cbxmountainman » Fri Oct 24, 2008 9:30 am
I stand corrected. Forgot about the top bracket that also holds the coils/condensor. Was refering primarily to the missing front down tube. That's my story and I'm sticking to it.
Re: CL Engine mounts
Post by LOUD MOUSE » Fri Oct 24, 2008 5:16 pm
It does hold the condenser all right. .............lm
cbxmountainman wrote:I stand corrected. Forgot about the top bracket that also holds the coils/condensor. Was refering primarily to the missing front down tube. That's my story and I'm sticking to it.
