can't get the cam apart
Goodysnap
Post by Goodysnap » Fri Oct 02, 2009 10:22 pm
Well I feel better. I'm going to attempt to weld it myself. It seems as though it is loose enough where I should do something with it. Thanks LM
64' CB77
65' CB160
Goodysnap
Not loose any more
Post by Goodysnap » Sun Oct 04, 2009 4:47 pm
I used the center punch to tighten the rivets , then welded it one spot at a time and let it cool in between. I did'nt recall seeing a pic of this so I thought I'd put one up. It appeared to be the best place to weld. The curved sides of the sprocket base are closer to the chain.
64' CB77
65' CB160
strikef1
Re: cant get the cam apart
Post by strikef1 » Sun Oct 18, 2009 11:10 am
LOUD MOUSE wrote:Chances are good ya melted the neoprene on the advance weights.
Ya will hear a CLICK, CLICK, CLICK when it runs if ya did. ............lm
As my Cam sprocket has been welded ->I do have this clicking sound when running; Should it be repaired? And how can you repair this?
Rob
maia
Post by maia » Fri Oct 23, 2009 5:43 pm
Where exactly is this neoprene anyway? I don't see any evidence of it on my sprocket .
Wilf
Post by Wilf » Fri Oct 23, 2009 5:55 pm
I don't know where it is, but I'm wondering too.
Goodysnap
Post by Goodysnap » Sat Oct 24, 2009 7:15 am
Well guys, I'm pretty sure the neoprene is on the Rivet/pin at which the advance weight rotates. I didnt dissasseble this area to confirm it ( fearing that I would do more damadge by removing the rivets) but I tend to believe the expert when he tells me it's in there. It appeared to be the only place it could be. That said , I'm still rookie status.
64' CB77
65' CB160
