Starter making noise
Re: E starter problems
Post by LOUD MOUSE » Sat Nov 27, 2010 8:03 am
Please add your location to your profile. ..............lm
oilyg wrote:Hi,
When you take the starter to pieces look and see how the bushing fits on the little sprocket side
on its steel nose.If too worn the starter will tumble a little in its bearings and not turn right.
A kit to repair it is sometimes on eb.On the back side of my rotor the 3 screws called screw flat m6x25 long are tightened and then punched on 2 sides in a little crevice or whatever you want to call it.That is to keep them in place.Maybe a drop of Loctite would help?Haven't tried that tho.
This forum is very helpful to me and I will try to help youall if I can.Keep em running.
oilyg
Post by e3steve » Sun Nov 28, 2010 8:15 am
Welcome to posting, oilyg. I agree with lm; please edit-in your location within your Profile link. It's nice to know where Hondatwinfans are based.
Your words read like a Brit's; are you UK-based?
Buck
Post by Buck » Mon Nov 29, 2010 9:24 pm
The starter on one of my Dreams does the same thing and with this same sound. I have replaced the springs,rollers and plungers with new ones but it did not solve the problem. The staked screws on the rotor are tight. Have not had the starter apart yet to check there.
oilyg
edited my location
Post by oilyg » Sat Dec 11, 2010 11:54 am
Edited my location now.Thanks for the tip.
I looked at a part fiche of the starter but they don't show if there is a bushing on the little sprocket side of the e-starter.If someone has his starter to pieces he can measure the nose of the starter and compare this to the bushing on the side.My bushing had so much play that it would run OK
off the bike and bind up under load.
I guess the things just wear out and thats it.
Could someone show a pic of the sprocket side open?( e starter I mean)
Thanks,
oily g
FluteTears
Post by FluteTears » Sat Dec 11, 2010 1:49 pm
Sorry all as I have been so busy getting house sold here in Aurora CO and now I am moving to Denton TX next Thursday I just not had the time to take this apart. After the move I will get to the problem and Report on what I find. I can say its allot worse when its 32F so it would seem to be a dry lube or worn parts problem.
Yes I have been riding in 32-40 F temps.
Cant wait to get to Texas LOL
Brad
1974 CT90
1964 CA77
