When I took off the head on my CA77 the 4 corner studs had the copper washers, the 4 center had the steel ones, all studs had acorn nuts. The copper washers are no longer available, but the 90441-286-000 WASHER, SEAL (8mm) still are. So I ordered and received 8 of the sealing washers and they are the steel ones.
I have read LM's comments (from many moons ago) on how Honda had changed to the 4x4 washer arrangement with 4 flat nuts in 1967 so I get all that. I guess I'm surprised that a "Sealing" washer is simply a thick steel washer. I can understand the copper washers called sealing, but what is sealing about a steel washer (I was expecting aluminum)? And... if the 4 corner studs require the copper washers to "seal", how come the parts book shows all 8 using the Steel Washer number, and will the steel washers.... seal? These are not zinc plated copper washers, they are magnetic.
tnx
George
65+ CA77
CA77 Head Sealing Washers?
That sounds like a fun idea. I have 4 used copper washers, I'll give it a try today.Jethro wrote:Just to make it known, you can anneal the copper washers by heating them up until they glow red then drop them in a container of cool water and they are just as good as new ones.
Just want to help save you guys some $$$$$:)
Jethro
tnx
George
Photo Restoration
Photo Restoration
The parts books and fiche for these old engines are not always correct as to the info they offer.
Things like screws/washers/nuts were changed over the years and the person assigned to upgrade the listing wasn't always correct with his info.
When these engines were in the early years (1958/1961) the engine actually used 10 copper sealing washers and cap nuts.
The first ones did use washers which looked copper then at some point they were zinc plated.
Like GEORGE said earlier on this subject I made comment on these parts.
I looked at my parts books and fiche for these engines and looks like none of then agree as to what was used over the years. (depends on the year of issue of the books/fiche)
I do recommend ya use the copper/zinc washers at the 4 corners and not to worry about the 4 center ones or the 2 at he lower case. ........lm
sohel951 wrote:I can understand the copper washers called sealing, but what is sealing about a steel washer (I was expecting aluminum)? And... if the 4 corner studs require the copper washers to "seal", how come the parts book shows all 8 using the Steel Washer number, and will the steel washers.... seal? These are not zinc plated copper washers, they are magnetic.
Photo Restoration
