Cl77 points cam
CFL
Cl77 points cam
Post by CFL » Wed May 22, 2013 8:22 pm
Just bought a replacement points camshaft. It has twin lobs. Is that correct? I thought a 305 cl77 only has one lob on the points camshaft. Thanks a million CFL
Re: Cl77 points cam
Post by LOUD MOUSE » Wed May 22, 2013 8:57 pm
If the lobs are 180 from each other ya have a DREAM part. .lm
CFL wrote:Just bought a replacement points camshaft. It has twin lobs. Is that correct? I thought a 305 cl77 only has one lob on the points camshaft. Thanks a million CFL
CFL
Post by CFL » Thu May 23, 2013 9:44 am
Thank you for the reply. The lobs are set in the normal area about 100 and 200 degrees. Does my cl77 305 have the same points cam? If so, do the dual points open at the same time? Thank you for the help. Sincerely, CFL
Post by LOUD MOUSE » Thu May 23, 2013 12:31 pm
They open at 90 degrees .
Like Bang, Bang, Exhaust, Exhaust. .......lm
CFL wrote:Thank you for the reply. The lobs are set in the normal area about 100 and 200 degrees. Does my cl77 305 have the same points cam? If so, do the dual points open at the same time? Thank you for the help. Sincerely, CFL
CFL
Points camshaft
Post by CFL » Thu May 23, 2013 8:05 pm
Thank you for the information. I can still fell a little raise on one side of the cam. Why? Thank you, CFL
Re: Points camshaft
Post by LOUD MOUSE » Thu May 23, 2013 8:24 pm
Did you compare it to the original?
It's a points cam and the coil fires when the cam opens the points.
Once open and the coil has fired "no big deal" with these as the dwell has been satisfied and you are good for another go round. ..... .......lm
CFL wrote:Thank you for the information. I can still fell a little raise on one side of the cam. Why? Thank you, CFL
CFL
points cam
Post by CFL » Fri May 24, 2013 10:01 am
It's the same cam. It will just fire on an empty cylinder. Thanks again, CFL
