DianneB
Post
by DianneB » Mon Aug 17, 2015 4:02 pm
About ready to split the case on my 1967 Dream to fix the kick-starter ratchet.
Anything I should watch out for when separating the halves? Anything going to fall out?
It looks like standard practice is to turn the case upside down to split it?
Never split a case before!
Post
by G-Man » Mon Aug 17, 2015 4:22 pm
Crank and gears should stay in the top (on the bottom ) half. If it looks like it is going to take force, stop and look for screws that you haven't undone.
DianneB
Post
by DianneB » Mon Aug 17, 2015 7:25 pm
DAMN those case halves don't want to split!
I read that Honda used a glue to join the case halves - is that true????
Post
by G-Man » Mon Aug 17, 2015 7:42 pm
Have you got the two M8 nuts that are through the top case, in the valley? There are some M6 bolts on the underside that often get hidden in the dirt between fins...
Post
by Seadog » Mon Aug 17, 2015 8:03 pm
DianneB wrote:DAMN those case halves don't want to split!
Close - Hondabond. You're going to need a tube for when you reassemble.
DianneB
Post
by DianneB » Tue Aug 18, 2015 11:07 am
G-Man wrote:Have you got the two M8 nuts that are through the top case, in the valley? There are some M6 bolts on the underside that often get hidden in the dirt between fins.
Thanks G-Man - I missed those two!
With the two sneaky nuts off, it came apart slick as could be!
Post
by G-Man » Tue Aug 18, 2015 5:41 pm
Glad you got that sorted.
Patience is your friend. Brute force less so...... :-)
DianneB wrote:G-Man wrote:Have you got the two M8 nuts that are through the top case, in the valley? There are some M6 bolts on the underside that often get hidden in the dirt between fins.
