piston sleeve bore question 305
choctaw
Post by choctaw » Wed Feb 03, 2016 11:03 pm
I bought a new set of pistons,rings, sleeves and wrist pins. what size do i tell the Machinist to bore my sleeves?( standard size pistons). +/- what?
DianneB
Post by DianneB » Thu Feb 04, 2016 5:29 am
What size rings did you buy? Standard? 10-over? 20-over? The bore diameter needs to match the rings.
Since you bough new sleeves I assume you bought standard rings so give the machinist the factory bore spec - should be in your service manual.
Re: piston sleeve bore question 305
Post by LOUD MOUSE » Thu Feb 04, 2016 8:49 am
How are you planning on installing the sleeves.
I give the cylinder assy with the sleeves installed and the pistons and the clearance that is in the book to the shop. ....................lm
choctaw wrote:I bought a new set of pistons,rings, sleeves and wrist pins. what size do i tell the Machinist to bore my sleeves?( standard size pistons). +/- what?
Tim Miller
Post by Tim Miller » Thu Feb 04, 2016 9:38 am
First, make sure sleeves are tight in cylinder ( .003 to .004" interference) then fit Pistons to bore with .002" clearance measuring at bottom of piston.
Tim
