Rebuilt engine seized
GregMcN
Post by GregMcN » Tue Jun 12, 2018 12:51 pm
Thanks Graham
When I get it stripped down again I will check for flatness and post some pictures. I did check the cases previously but I could of missed something and can not remember if I checked the barrel.
Greg
pemdoc65
Post by pemdoc65 » Tue Jun 12, 2018 1:00 pm
I had a similar leak when I reassembled the engine for my CB72. I disassembled it again, and found that two of the cylinder studs were not fully threaded into the bottom case. It was causing those two head nuts to bottom out before reaching proper torque. I used a stud installer to screw the two studs further into the block, and it solved the problem.
GregMcN
Post by GregMcN » Tue Jun 12, 2018 3:42 pm
Thanks Pemdoc
I did check that none of the nuts were bottoming previously but I will recheck again when l reassemble.
GregMcN
Reason for leak
Post by GregMcN » Wed Jun 13, 2018 12:26 pm
On checking although the crankcase is flat there is a dip on the barrel adjacent to the 9th hole.
The pictures show flatness of the crankcase, and then the barrel either side of the hole and then the dip that is causing the problem. I have tried to measure and my best estimate is about 0.15mm at the edge , maybe a bit more over the hole.
Greg
Re: Reason for leak
Post by G-Man » Thu Jun 14, 2018 1:00 am
Hi Greg
Now we have a reason for the brass tube and the leak.
It will be necessary to heat the barrel to drop out the liners and then the bottom face can be skimmed flat. A pretty simple job which should sort the leak.
GregMcN wrote:On checking although the crankcase is flat there is a dip on the barrel adjacent to the 9th hole.
Greg
GregMcN
Post by GregMcN » Tue Jun 19, 2018 2:47 am
Liners removed without problems, though undecided about skimming the existing barrel which has some fin damage or getting liners fitted to another barrel.
Greg
GregMcN
Post by GregMcN » Tue Jun 19, 2018 3:24 am
When you replace the liners do you coat with anything. I think I saw krylon mention in a post but was not sure what that was.
Greg
