Timing chain marks
Hahnda
Post by Hahnda » Wed Jul 08, 2015 11:17 am
No need to align the master link with the mark.
Mark must be perpendicular to top surface. Its off by at least one tooth. Maybe more.
gbyoung2
Post by gbyoung2 » Wed Jul 08, 2015 12:41 pm
Hahnda wrote:No need to align the master link with the mark.
Yes, understand the position of the master link is irrelevant; obviously, cam timing mark is.
I'm thinking it's off by one. If you mentally rotate the cam CW, paying attention to the "0", one tooth would put it in alignment with the center line of the crank, up through the engine, and the center line of the cam. That's the way I'm visualizing it, but proof will be once I swing the chain up over the sprocket and see where the marks fall.
On this particular engine, it appears that the "0" mark is dead center of the horizontal flat of the advancer plate. That being said, when everything is aligned properly, that flat should be parallel with the top of the head. Again, we'll wait until the chain gets put in place and see what we have.
http://gbyoung2.smugmug.com/Motorcycles ... 014-X2.jpg
http://gbyoung2.smugmug.com/Motorcycles ... 016-X2.jpg
gbyoung2
Post by gbyoung2 » Sat Aug 29, 2015 11:53 am
Finally had a chance to get back on the 305. Feel pretty comfortable with the cam timing, but would like a final critique before I fully install the master link and button it up - just to be sure:
https://gbyoung2.smugmug.com/Motorcycle ... 004-X2.jpg
https://gbyoung2.smugmug.com/Motorcycle ... 003-X2.jpg
TIA
CAM CHAIN TIMING
Post by LOUD MOUSE » Sat Aug 29, 2015 1:46 pm
You have it correct. ................lm
gbyoung2 wrote:Finally had a chance to get back on the 305. Feel pretty comfortable with the cam timing, but would like a final critique before I fully install the master link and button it up - just to be sure:
TIA
gbyoung2
Re: CAM CHAIN TIMING
Post by gbyoung2 » Sat Aug 29, 2015 3:08 pm
LOUD MOUSE wrote:You have it correct. ................lm
TIA
Good!
Thank you for looking.
Guy
Post by LOUD MOUSE » Sat Aug 29, 2015 5:46 pm
You are welcome. ...........lm
TIA
Good!
Guy
OldScrambler
Post by OldScrambler » Sun Aug 30, 2015 8:34 pm
Suggestion..........clean the threads on the studs and then oil with 30w to get a good consistent torque reading..........
