rickytile wrote:ok ,
1. the engine was running rich because these was gas in both exhausts. the screws were turned 3.5 times by the way on the other (richer side) the one that popped was 2.5 turns. those carbs were never tuned the same though, it just didnt work that way, not suure thats the normal thing or not though. i know the tunining standards though caled for .5 to 1.5 turns only (max) . probably has to do with the increased displacement. the jet were set in the middle (default) .
The idle mixture screw controls air, not fuel. So when you open it up, you make it leaner.
Fuel in the exhaust is a complete mystery to me. With the bike running, you had raw gas in the exhaust?!! Hard to believe bike even ran. I would have expected that fuel to have eventually ignited resulting in one mutha of a backfire.
An overly lean mixture can cause an engine to backfire on decel. Too lean to fire in the comb chamber and pumps air/fuel mix into mufflers and when the mixture is right or the cylinder fires, BANG it pops out the exhaust. Very common in FI bike with low end mixture set too lean.
2. ok so yes, the engine must have been over heating. the run i did just before this one, the first for top speed, the engine started to smoke alot after the run (burning oil) . for future referemce, is this an indication of overheating?
Might have burned oil because there was poor ring sealing at first or you had an overabundance of oil in the engine and ports from the rebuild. But if you used a synthetic oil it could very well be that the rings would not seat. I've seen this before.
3. plugs i was running are NGK D8HA
4. timing, i will redo this but does bad timing have any sound indicators? i had a pro do the timing for me so i figured that was the least of the problems.
Getting paid to do work does not mean you are good at doing work. Horror stories abound for shops ruining well running bikes.
5. is there any way i can inspect for pinging now with the can open. should there be marks? because the bike would make a pinging type sound around the cam but i heard that was normal and not pinging by the mechanic. could tha have contributed cause?
I can see evidence in your photos. Top of the piston looks like somebody went at it with an ice pick. That is a textbook example of the effects of pinging.
You won't hear pinging at idle. It occurs under load. Mechanical lifters will rattle when the bike runs and mechanical noises are normal. But pinging is a very high pitched pink or ping sound that does not necessarily have a regular cadence to it like valve clatter. Best analogy for the timing of the pings is like crumpling up a piece of paper.
Excessive valve lash did not contribute to this failure.
6. about the molten aluminum. i have cleaned it out of the globe, it looks like some is in the exhaust port (more than the other side) ill assume because of the vacuum effect of the engine. does that need to be cleaned out? (looks like some on the valve stem) also i would hate to rebuild more than the top end. i have a magnetic plug on the bike. should that be good enough. (cleaning in frequent intervals)
Holy crap. Aluminum is not magnetic. If you do not know that, perhaps you should not be digging into this bike. Don't mean to offend, but this is pretty basic knowledge. I'm hoping you just had a brain phardt.
7. what oil filter should i clean, the one at the pump? or the one on the side. that one is a pain the ass to take apart by the way. any suggestions on how to open that one would be appreciated, but first is it necessary.?
If you want to be sure, follow Gman's advice and strip the engine. Next best bet is pull the oil pump and make sure it is clean. You could even dump a gallon of kerosene or similar thru the bottom end with the pump out, filter it to remove the swarf, and run it thru again. Do this until no more swarf shows up in your filter.
By all means clean the spinning filter. I'm amazed that you are asking that question.
btw, this hurts, i had about 500 miles on this rebuilt engine.
8 . one more, sorry,.. i had put in a new clutch basket. after about 400 miles, if you tried to feather into second gear the bike would not catch it right off, but kind off neutral out then suddenly pop into 2nd real brash seems like something would eventually break; the only way to get it in confidently was to pop it in a higher than mid rpms. any explanations for this? this may lead to taking the whole dam thing apart.
Sorry, but I don't understand your description or what you are asking. Not sure how you "feather" a tranny into gear. Shifting should be firm and positive, not slow and wimpy.
i put too much work into this bike for this, heres what she looked like before the black friday. also what i originaally bought her as (crazy)
Please don't take offense at my comments. If I think somebody might be better off not touching something because of inexperience, I just say it. It's your bike so you have the final call, of course. But if you just bought a bunch of parts and put them together without understand things like piston to cylinder clearance, ring end gap, carburetion set up, etc.. then I don't think you should be fixing this yourself unless you plan to do a lot of studying and learning before you begin.
regards,
Rob
