connecting rod sleeves?
Farm Shop
Post by Farm Shop » Fri Dec 12, 2014 2:30 pm
Their suggestion was also to dismantle the crank which I was trying to avoid doing because everything else on the crank is in very good shape. And not to mention the cost of it.....
I was thinking maybe finding the right size bearing set collar to place on the reamer so it would butt square to the face of the rod when reaming?
I know that also wouldn't by any means be exact but it would be better than the eyeball method!
FS
48lesco
Post by 48lesco » Sat Dec 13, 2014 12:05 am
See this post:
http://www.honda305.com/forums/piston-p ... 308-7.html
I had good success with the hand reamer, but there was much controversy in the 305 realm...
I still have the fixture if you want to use it, just send me a pm with your address.
Farm Shop
Post by Farm Shop » Sat Dec 13, 2014 11:55 am
Thank you for chiming I came across your post earlier and was curious how it was running a couple years later!
I think the method you used is how I will go about it when my oversize pins arrive.
I have the cases split so I may try and make a fixture on my bench to hold the crank when I put the rods in the vise.....
But I will see how it goes and maybe I will take you up on the tool rental.
Again thank you much!
FS
48lesco
Post by 48lesco » Sat Dec 13, 2014 6:07 pm
I put about 1000 miles on that bike after the oversize pins with no issues.
Farm Shop
Post by Farm Shop » Wed Dec 17, 2014 8:39 pm
After some searching I may put this idea on the back burner and just look for a different crank entirely......
There is a salvage yard not too far from me that has a pretty good number of cranks I can physically go look at.
The cranks are all the same from 65 to 68 in the 305 scramblers correct?
jugger18
Post by jugger18 » Wed Dec 17, 2014 8:52 pm
What salvage yard?
Farm Shop
Post by Farm Shop » Wed Dec 17, 2014 9:03 pm
Mr. C's motorcycles in Appleton.
Bought a head and a tank from him both of which are in great shape
Its a bit of a drive but I can't buy a crank without looking at it....
