Smoking
DianneB
Post by DianneB » Mon Nov 16, 2015 6:05 am
I just did the engine on my '67 Dream - honed cylinders and new rings - and it was doing the same thing initially.
The rings I got were not bevelled so there is no top/bottom.
I was advised (by a race engine builder) to run a tank of gas/oil mix for the break-in and the mixture was also excessively rich so it was pretty smokey.
By the time the first tank of gas was burned I had the mixture sorted and it is running just fine now.
I have been around engines my whole life and never heard of "glazing the cylinders" from a rich mixture so my advice is to fix your mixture problem and give the engine a reasonable break-in time before worrying about smoke.
apeonwheels
Post by apeonwheels » Mon Nov 16, 2015 10:12 am
Thanks, that`s exactly my plan. Tim is right I guess, too, the super rich mixture can wash the oil off the cylinders and may lead to excessive wear that is manifested in glazing. But i think that requires a bit more time of usage than letting run the engine for a couple of hours total in the garage. Now I have to figure why my mix is so rich. I suspect the needle jet holder and needle pair, I read some posts here and it is still not clear to me how these two have to be positioned to each other. Also, when I rebuilt the carbs I got them soaked in carb cleaner and forgot them there for a couple of days, and the stuff dissolved off a bit of stuff other than dirt that may be the problem too.
Post by LOUD MOUSE » Mon Nov 16, 2015 10:15 am
What rings did you get?
Were they HONDA?. ...............lm
DianneB wrote:I just did the engine on my '67 Dream - honed cylinders and new rings - and it was doing the same thing initially.
DianneB
Post by DianneB » Mon Nov 16, 2015 11:39 am
LOUD MOUSE wrote:What rings did you get?
Don't remember specifically but think they were after-market replacements.
Post by LOUD MOUSE » Mon Nov 16, 2015 1:21 pm
Usually rings even after market for these engines have a top with LITTLE/SMALL letters/numbers.
The top ring is usually silver and the second black then the oil ring.
The first has a small cut back on the top and the next one a larger cut back on the bottom.
Did you look for numbers/letters?. ..............lm
DianneB
Post by DianneB » Mon Nov 16, 2015 4:57 pm
LOUD MOUSE wrote:Did you look for numbers/letters?. ..............lm
Nope.
Post by LOUD MOUSE » Mon Nov 16, 2015 6:16 pm
OK?. ...........lm
Nope.
