CB77 - Oil leaking woes
Post by LOUD MOUSE » Fri Jun 02, 2017 6:54 am
Don't be surprised if it pops out. ..................lm
Nick wrote:When installing the crank seal, use gasket sealer on the outer seating surface of the seal. This makes the seal easier to install, will help prevent damage during installation and will also help prevent leaks.
As with any engine, excessive oil leaks can also be caused by combustion pressure leaking past the rings and pressurizing the crankcase.
DJM
Post by DJM » Fri Jun 02, 2017 4:59 pm
In fact, be surprised if it doesn't. If you use any sort of none setting sealant on the edge of the oilseals you're inviting them to come right back out again, don't ask me how I know!!
Post by LOUD MOUSE » Fri Jun 02, 2017 5:26 pm
You and a couple of others are why I offered that. ...............lm
DJM wrote:In fact, be surprised if it doesn't. If you use any sort of none setting sealant on the edge of the oilseals you're inviting them to come right back out again, don't ask me how I know!!
