Pistons for Overbore Kit
hondauser
Post by hondauser » Fri Aug 15, 2003 3:40 pm
i am trying to do my own overbore kit with<br /><br />2 1000 cbx std pistons with rings<br />( same piston pin 15 MM DIAMETER)<br />BUT NEED BIGER SKIRT =overboring cylinder blok<br /><br /> 125 xl ,xls ,pistons may be used<br /><br />750 cb K1 also(same piston pin diam.)
cb 72
cb 77 ,c77 ,cl77
velocette thruxton
TerraRoot
Re: Pistons for Overbore Kit
Post by TerraRoot » Tue Sep 23, 2003 1:54 pm
i have cb750 pistons and i am going to try to them in a overbore.<br />race bikes used a ASSO kit with 10.5:1 pistons <br /><br />hope this helps good luck with the cbx or xl piston idea
DJM
Post by DJM » Thu Oct 09, 2003 1:56 pm
I can supply the Asso Race pistons from stock if you are interested.
sprocket
Post by sprocket » Sat Feb 21, 2004 10:45 am
DJM wrote:<br />I can supply the Asso Race pistons from stock if you are interested.<br />
Deano
Post by Deano » Fri Apr 09, 2004 6:25 am
<br /><br />Can you send me some info one the Asso pistons. How do they differ from standard and $$ if available??
own swamp mc
Post by own swamp mc » Sun Apr 11, 2004 5:12 am
I use kawa gpz 750 pistons
brad
Post by brad » Wed Sep 22, 2004 4:44 pm
I have a complete 350cc overbore that is on my 305 now. I would trade even for stock parts as i do not need the added power. Swap would include cylinders and pistons, cylinder head. Please note that you will have to make your own head gasket out of copper. Also the spigots (bottom of the cylinders) are very thin but have not caused any problems in appox. 500 miles. e-mail me at stphns@hotmail.com if interested.
