Kickstart has no resistance
Dogsbd
Post by Dogsbd » Wed Aug 13, 2008 5:49 pm
1966 CA77
Kickstart doesn't seem to be engaging. No resistance at all, stator doesn't move when kicking the kickstart lever. When in gear however kicking the kickstart lever does turn the rear wheel.
Help!
Hahnda
Post by Hahnda » Thu Aug 14, 2008 9:21 am
Clutch out of adjustment?
Dogsbd
Post by Dogsbd » Thu Aug 14, 2008 10:03 am
Hahnda wrote:Clutch out of adjustment?
Could be... but does the kick start act through the clutch?
Hahnda
Post by Hahnda » Thu Aug 14, 2008 10:26 am
I know that if you have it adjusted to tight it will just like you have the clutch lever pulled in. If you try to kickstart the bike with the lever in it doesnt work.
Dogsbd
Post by Dogsbd » Thu Aug 14, 2008 11:16 am
Hahnda wrote:I know that if you have it adjusted to tight it will just like you have the clutch lever pulled in. If you try to kickstart the bike with the lever in it doesnt work.
Oh I see, so it forces you to have the transmission in neutral to kickstart? Ingenious!
Hopefully that is my issue, I'll check tonight / this weekend. Thanks!
