gas in the oil
Rick Green
gas in the oil
Post by Rick Green » Thu Aug 21, 2008 7:55 pm
I just purchased my 67 Dream (Mom said no when i was 16 in 1967) I got the engine running and tuned up before putting it to the road I changed the oil. Seems the old oil was dark but smelled like fuel was in the oil. I just got back from my first 5 miles and checked no signs of fuel in oil yet. Has anyone ever experanced this before? Hate to drive it to much and have the engine lockup.
Thanks Rick
Post by davomoto » Fri Aug 22, 2008 10:06 am
Rick, that usally occurs if float level is too high, or float needle is worn out and petcock is left in on position when parked. Basically the fuel from the carb runs down the intake, floods the cylinder, and ends up in the crankcase. This will aslo cause the bike to run rich. If you're confident that none of these conditions exist, then I say ride it!
Rick Green
Post by Rick Green » Tue Aug 26, 2008 8:34 pm
Never knew you had to shut the gas off I'll give it a try Also have had no fouled plugs since oil chamge. Thanks
