timing belt adjuster 61 305 dream Ca77
jthomp
Post by jthomp » Sun Jan 25, 2009 10:15 pm
I have a question for you folks that have worked on the timing chain adjuster. I was trying to loosen the side screw on mine and it seems to be frozen pretty tight. Is that set screw loosened allow the spring to tighten? Is that chain tenioner removable without R&R motor?
deaddog
Re: timing belt adjuster 61 305 dream Ca77
Post by deaddog » Mon Jan 26, 2009 11:13 am
jthomp wrote: Is that chain tenioner removable without R&R motor?
If you are talking about the cam chain adjuster than yes you can remove it by removing the four bolts. You can then check the condition of the roller and if it is frozen un- freeze it.
jthomp
61 305 dream
Post by jthomp » Tue Jan 27, 2009 2:40 am
I tried to losen the small 6 mm bolt on the outside of the chain adjuster...Afraid I'm going to break it off as it is very tight....The book said to loosen it to adjust the chain. Is it a set screw and the other shaft moves in and out to adjust the chain?
deaddog
Post by deaddog » Tue Jan 27, 2009 6:40 am
It should have a jam nut that you back off and then back the bolt off and then the rod should move. If you feel it is frozen, you need to remove the adjuster assemble. Very easy job: just remove the four mounting bolts and remove the whole thing. You might need to get a gasket to put back on. I used gasket sealer and it does not leak.
jthomp
61 305 dream
Post by jthomp » Wed Jan 28, 2009 2:46 am
Thanks for the help....I am going to remove it and see if it is working
jthomp
61 305 dream
Post by jthomp » Wed Jan 28, 2009 2:47 am
jthomp
61 305 dream
Post by jthomp » Wed Jan 28, 2009 2:54 am
Thanks for the help....I am going to remove it and see if it is working. This unit hasn't been started in over twenty years and I started it the other day...It had like a loud chain noise at start but it started and ran pretty good considering all I did was clean and gap the points..I also noticed the points plate is moved all the way to one side....could that mean the chain is worn..."stretched"
