Compression tester recommendations
brewsky
Post by brewsky » Thu Oct 08, 2009 5:56 pm
Anyone have an Actron compression tester.
If so, any issues using the 12 mm adaptor in the head?
TIA
brewsky
Post by brewsky » Fri Oct 09, 2009 5:37 pm
Went ahead and got one.
Works great and has several size adaptors.
http://www.autozone.com/autozone/catalo ... ame=Actron
brewsky
Post by brewsky » Fri Oct 09, 2009 6:12 pm
OK, 135 LEFT CYL, 140 RIGHT CYL
engine cold, dry test, wide open throttle, air cleaner in place
Need I go any further??
Goodysnap
Post by Goodysnap » Fri Oct 09, 2009 7:40 pm
Rerun a wet test , just to see what the change is . I wouldnt be ashamed of those numbers.
64' CB77
65' CB160
brewsky
Post by brewsky » Wed Oct 21, 2009 5:20 am
Re-ran hot dry and hot wet tests, this time with air filter off:
141, 149..dry
150, 150..wet
But I'm wondering now if I had the tester snugged up enough on the 141 reading!
Time for another test.
chico
Post by chico » Wed Oct 21, 2009 5:32 am
Bill Silver says, 160 to 175, but that's right out of the box.
chico(steve)
66 CB77
ride safe
