removing rocker arm pins
is there anything i can use to get these pins out if i dont have that special tool? (other than a big hammer) ?
rockers
the head has to be off block studs, take a big flat bladed screwdriver and get the pins moving in the head then find a screw that fits the thread in end of pin and pull them out.
chico(steve)
66 CB77
ride safe
66 CB77
ride safe
pins
You can make your own puller by using a 6mm bolt and a socket that is slightly larger inside diameter than the pin. That will pull it out far enough to get a plier on it for further removal.
RW
RW
Re: removing rocker arm pins
As ya look at the Small End ya can use a Long Punch or Rod and knock it out far enough to use the punch/rod to pry them out at the area where the stud passes through.
Quick, simple and no special tools. ..........lm
G-GAURD wrote:is there anything i can use to get these pins out if i dont have that special tool? (other than a big hammer) ?
6mm worked perfect
thanks the bolt and socket worked perfect
While ya are just completing the first one I have all of them out. ..........lm
houseowax wrote:FWIW I just used a 6mm bolt, threaded it in about 1/2" then yanked it out with a pair of LeverLocks clamped on the head of the bolt.
