Trick to getting rotor back on?
bpdinse
Post by bpdinse » Sat Dec 18, 2010 8:39 pm
Yeah - I'm green at this. I searched the forums after looking through B. Silver's guide - couldn't find info on it. As I can't find it, it must be so simple and that means it is me... well, I am okay with sounding stupid.
So I am trying to get the rotor back on. The three rollers in the starting clutch are forced outward by springs. That is keeping me from getting the rotor w/starting clutch assembly onto the starting sprocket (which is on the shaft). I even tried to get the starting sprocket onto the back of the rotor while sitting on the bench before putting it on the shaft just to see if I could do it. I could not do it. Even if I could do it on the bench that way, I know I can't then put it on the shaft because I need the key installed on the shaft.
Can someone kindly clue me into the method of assembly of the rotor onto the shaft/starting sprocket?
Much appreciated!!
Brian
Post by davomoto » Sat Dec 18, 2010 8:49 pm
Brian, if I remember correctly, you can push the rotor on by hand, and push / spin the starter sprocket and get it to go in the rollers, or turn the rotor itself, spark plugs out of course.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
bpdinse
Post by bpdinse » Sat Dec 18, 2010 9:40 pm
That did it - thanks!!
I don't kow why I didn't at least try something like that. I just rotated the rotor as you said while pushing it onto the shaft/starter sprocket, Davo, and the rollers went up over the edge of the starter sprocket and the rotor slid the rest of the way on.
I appreciate the help!
Brian
Post by davomoto » Sun Dec 19, 2010 11:57 am
Excellent Brian, and thanks for posting the solution.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
