Valve cover gasket?
yellow60
Valve cover gasket?
Post by yellow60 » Sun Jan 16, 2011 9:18 am
I put back together a 67 CA77 motor last night after new rings and seals. After patting myself on the back I decided to tear down another old seized motor I believe this one to be a 1965. The question I have is the 1965 has a metal gasket/cover that covers the valves. It is large flat piece with a rectangle cut out where the timing chain runs through. To help better describe this is the first thing you see after you remove the eight acorn nuts on top of the motor and remove the top of the motor. My 1967 did not have this metal and they only uses a gasket with the valves visible. What gives?
Thanks Adam
Re: Valve cover gasket?
Post by LOUD MOUSE » Sun Jan 16, 2011 10:03 am
All these engines came with that metal (steel or aluminum) and ya need to have it in there. ..........lm
yellow60 wrote:I put back together a 67 CA77 motor last night after new rings and seals. After patting myself on the back I decided to tear down another old seized motor I believe this one to be a 1965. The question I have is the 1965 has a metal gasket/cover that covers the valves. It is large flat piece with a rectangle cut out where the timing chain runs through. To help better describe this is the first thing you see after you remove the eight acorn nuts on top of the motor and remove the top of the motor. My 1967 did not have this metal and they only uses a gasket with the valves visible. What gives?
Thanks Adam
yellow60
Post by yellow60 » Sun Jan 16, 2011 10:28 am
Thanks for the fast response Loud Mouse. Does a gasket go on each side of the metal?
teazer
Post by teazer » Sun Jan 16, 2011 10:35 am
Yes
mike1969
valve cover gasket
Post by mike1969 » Sun Jan 16, 2011 10:45 am
I can attest to the importance of the valve cover and putting the cover on with the 2 small rectangular holes facing the front of the bike.
Read my post about engine blow by. I rebuilt my Dream engine and forgot to replace the plate when I put it back together. I had an extreme amount of oil coming out of the engine breather hose. I fought that thing for about 7 months trying to figure it out. Loud mouse finally steered me in the right direction,but when I put the plate ,I put it back on with the 2 holes facing the back of the bike. I still had the blow by. After speaking to lm by phone he reminded me that the 2 holes should face forward.
I reinstalled the plate and the blow by is gone.
yellow60
Post by yellow60 » Sun Jan 16, 2011 12:25 pm
You guy have already saved me a lifetime of frustration in the last few months.
I have never met loud mouse but I imagine him at a Honda manufacturing plant with a section full of restored Honda's with a team of employees around him helping answering questions for us all.
Thanks a million.
