Where does the castle nut go?
arseatea
Post by arseatea » Sun May 01, 2011 2:44 pm
Sorry, I am not good at posting pictures. My Clymer handbook shows pictures of this castle nut below the bottom of the case, but it does not show exactly where it goes. They call it a 'sealing nut' and the washer is called 'washer A'. Can you help me with the correct location? Thanks for all your help..Ron
rrietman
Post by rrietman » Sun May 01, 2011 5:47 pm
it's not a castle nut. it's a 6mm blind nut with an aluminum sealing washer. it goes to the right of the oil pump flange when looking at the bottom of the engine with the cyl facing away from you.
Randy
arseatea
Post by arseatea » Tue May 03, 2011 12:41 pm
I started to install the nut at this location, but other than the proper thread size, nothing else seem to fit. Presently as the nut stands, the aluminum washer is situated about 1/3 the way up on the outside of the shaft of the nut and is formed in a crescent-like shape. Like it was fitted into an indentation or something. I could probably remove the washer with a drift or chisel, but I wonder how the hole in the washer got so big that it was able to fit over the nut shaft. Installed as it is, it does not appear to really seal anything. I know that there must be a reason Honda installed this type of bolt there, but I cannot see why. Thanks for any additional information..Ron
Dana01
Post by Dana01 » Wed May 04, 2011 5:24 pm
If the washer is bowed replace it. Remove it carefully along with any loose bits that may have gotten stuck in the stud threads.
You may want to chase the threads with the correct size die.
Dana
1966/7 CB-77 Red of course
