Odd top end noise
Odd top end noise
So I found a donor 67 CB77 to complete my 64 with. The motor seems to be in good shape, but when rolling it slow by hand to check valve gap and timing I noticed something strange. As the advance marks (double slash) passes the pointer there is an audible "click". If I touch the exhaust rocker I can feel it, but I see no noticeable delay in valve movement. I'm not certain its the valves but it is definitely in that region. The only other thing I can think of is the cam chain. It happens like clockwork, even if you roll back a few degrees and then forward again. Anyone have any thoughts on this?
I think I saw that, about the neoprene bits on the advance unit.
A bit more investigation with a stethoscope shows it is definitely the valves, each one shuts with an audible "click". You can feel it if you place your finger on the rocker. I presume these valve systems run quiet normally? (I have little experience with these bikes)
The valve clearance is dead on.
mike in idaho
Might be some slack in the timing chain. As the rocker goes over the top of the lobe, the spring pressure causes the cam to jump ahead a few degrees.Watch the end of the points cam to see if there's unusual movement when the click sound occurs.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
Click
Mike may be onto something. There are some things that we don't know.
How many times to you hear the click in 2 complete revolutions (1 complete run of all 4 cycles)? That should help determine if it is one or both exhaust valves. Since it is a 360 degree engine it would make sense there would have be two "dead" spots (if there is one) where there is not tension on the cam chain (if that is the cause0 but I don't know for sure. If it only clicks once that would seems to indicate something in one cylinder.
If that is not it, then it would seem to have to be one cylinder's valve/guide, tappet/shaft or a cam issue like the spline problem that Hahnda had. It might be a good idea to get some good video of what it is doing before you take it apart in case it turns out to be something totally different and you would want to verify what you find when it is disassembled.
Hope that helps.
Hope that helps.
