Camshaft Bearings
Tinman
Camshaft Bearings
Post by Tinman » Wed Oct 02, 2013 6:46 pm
Is there a secret "DIY" method to removing and installing the bearings onto the camshafts?
Or is this something that needs to be taken to the shop.
Unfortunately, I cannot locate any information on how it's done. I have my ideas, but before I spend $$ on tools, I thought I'd ask. Thanks in advance.
Tinman
Post by G-Man » Thu Oct 03, 2013 4:35 am
Camshaft in the freezer. Warm the bearings gently. If they don't slip on, Just tap them on with a hollow socket or piece of pipe that contacts only the central part of the bearing, not the outer.
Tinman
Post by Tinman » Thu Oct 03, 2013 11:00 am
G-Man, thanks. To remove the old bearings, do you heat the bearing and tap out the cam?
Post by G-Man » Thu Oct 03, 2013 12:03 pm
A bit of heat will help but if you are going to scrap the bearing it doesn't matter if you hold the outer race ( in the vise ) and tap the shaft through with a brass drift. If you are ever going to reuse the bearing, putting impact through the balls should be avoided.
Tinman
Post by Tinman » Thu Oct 03, 2013 2:33 pm
G-Man, it worked like a charm! Once it started to move it was piece of cake. Thanks for the assistance.
Post by G-Man » Thu Oct 03, 2013 2:54 pm
Tinman
You're welcome. It's always good to help.
