CA to CL swap????
CA to CL swap????
are the engine mounts the same on a ca77 to a CL77 for the 305. I am interested in putting a CA77 engine in a CL77 frame. Thanks in advance for the help.
Top cover on the engine is different and the CL uses a special oil pump casting with an additional bolting point. The top cover will swap and the oil pump shouldn't foul on anything.
I'm told that the central CA77 carb will clear the frame tube.
