oil filter
versuspop
oil filter
Post by versuspop » Thu May 08, 2014 8:42 pm
Hi all!
66CB77
should there be a washer (part 20 in the diagram) between the oil filter and the engine case?
seems like yes, but i did not see one when i opened up the side cover. (of course, when i opened the chain side, a nail fell out)
Ian
65 CA77
66 CB77
71 CB450
73 CB350F
Hoosier Tom
Post by Hoosier Tom » Thu May 08, 2014 9:10 pm
No, it goes between the outboard side of the filter and the oil filter cover that gets mounted to the clutch side cover. You slip the washer onto the oil filter shaft then slide the shaft through the filter.
This photo was previously posted by Wilf.
http://www.honda305.com/forums/download.php?id=5176
HT
versuspop
Post by versuspop » Thu May 08, 2014 9:27 pm
thanks--although it is still missing....
hope it is not in the transmission some how.
Ian
65 CA77
66 CB77
71 CB450
73 CB350F
Geeky160
Post by Geeky160 » Sat Jun 14, 2014 7:39 pm
Sadly, I finally checked my oil filter and the washer had been installed in the incorrect position. It's been like that for several thousand miles in the last 15 tears. The guy that rebuilt it is the "guru" in Albuquerque and is still in business. He has had a vintage cycle junkyard for many years. maybe he let his flunky did the work. Not endorsing them but here is the website.
http://southwestmotorcyclesalbuquerque.info/
'67 CL77 (337, gears X'd)
'65 CB160
mcconnellfrance
Post by mcconnellfrance » Sun Jun 15, 2014 2:14 pm
Apparently there used be some confusion about the location of this washer. It is clarified as HT says, on the outside of the filter, in Bill Silver's restoration manual.
