I'm overhauling a CB77 engine that was not running when I took it apart. Now that I have it going back together, I see that the kickstart shaft goes though the transmission shaft, and into an over-run assembly that connects to gears that are engaged at all times.  This seems to mean that while the engine is running, the ratcheting overrun assembly will be clicking away. Does this seem right?  My CA95 had a disengagement feature, It seems the CB77 doesnt.  Wont this ratcheting overrun wear out pretty fast if its ratcheting away at all times the engine is running?  Just curious of others experience with this design, and if I have put it together right.
Mike
                    CB77 kickstart
				Lassociety
				mike in idaho
It doesn't ratchet all the time. When the kickstart shaft is retracted by the spring, the stop in the crankcase retracts the pawl. If it ratchets while the engine is running you need to pull the sidecover off and re-position the shaft in the splines.
									'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
						'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
				Lassociety
				kfsrq
I had the same trouble.
Please study the thread "Ticking Noise". I think you will find it near this thread.
My project was stalled for a long time because I thought I had made a mistake in assembly, because I had not yet installed the parts that kept the noise from happening. Several helpful people guided me on how to proceed, and in a short time I was riding my CB-77.
I rode it again today, and it works fine. A few issues remain, but the bike is reliable.
Good luck. I hope your machine is as much fun as mine!
Keith
Keith
