Every single rubber pipe on my CB77 was missing when I got it, & looking at loads of photos & other searching, I still can't work it out, SO,
1 x nipple in the middle of the head top cover pointing rearwards,
2 x sticking out of the lower rear of the head by the carbs,
1 x on each of the new air-filters pointing forwards.
Then there's 1 on each fuel-bowl pointing rearwards & down, what goes where & the routing please.
Different question, here in the UK, what oil for the engine?
Tubing
Re: Tubing
modelman wrote:Every single rubber pipe on my CB77 was missing when I got it, & looking at loads of photos & other searching, I still can't work it out, SO,
DOWN THE BACK OF THE HEAD ON THE LEFT SIDE OF THE CAM CHAIN TENSIONER INTO THE VALLEY OF THE UPPER CASE TO THE RIGHT AND NEAR THE HOLE WHERE THE SPROCKET IS ON THE OTHER SIDE OF THE CASE.
A PLASTIC "Y" WITH TUBING TO BOTH OF THOSE AND THE SINGLE GOES TO THAT VENT ON THE RIGHT AIR CLEANER.
CLOSE OFF THE LEFT SIDE AIR CLEANER TUBE.
NOTHING GOES ON THESE ...............................lm
