Exhaust leaking from kickstart engine case
There seems to be exhaust leaking from the engine case behind the front sprocket. I haven't had the engine running with the case off to see where it's coming from. Is this a common issue?
Re: Exhaust leaking from kickstart engine case
If your engine has the breather tube from the top installed under the engine center cover what you see may be case pressure being exited there.
What engine work have you done?. ..............lm
StillNDADIRT wrote:There seems to be exhaust leaking from the engine case behind the front sprocket. I haven't had the engine running with the case off to see where it's coming from. Is this a common issue?
Got it.
Actually nothing should show from that tube unless it has tired rings or the top of the engine installed with the gaskets (2, one metal and one fiber) installed wrong. ......................lm
StillNDADIRT wrote:I haven't been in the engine yet. I'm told by the previous owner that the owner before him drag raced the bike so who knows. That owner also put ape hanger handlebars on and chromed everything he could if that tells you anything.
