Gas in crankcase
roadcapDen
Gas in crankcase
Post by roadcapDen » Wed Oct 12, 2011 7:01 am
305'rs,
Noticed my rebuilt S'Hawk's oil level was a little bit high so I drained some off and there is gas in there?
Bike only has a few miles since rebuild because it's bogging bad, fouls plugs and some times when it runs only left side is hot.
Is blowing some oil out the pipes but thought it is because it's still breaking in.
The floats (which are good) are set to proper level and they are not overflowing.
How is the gas getting in there?
Thanks all,
roadcapDen
2 HD XL's
65 Dream 305
and a bunch of other scoots
Post by davomoto » Wed Oct 12, 2011 10:18 am
Float sticking or improperly adjusted allowing fuel to flow into the intake. The gas in the oil will cause it to run rich.
Davo
roadcapDen
Post by roadcapDen » Thu Oct 13, 2011 8:12 am
Thanks!
UPDATE!
Drained the oil last night to the tune of about 2 litres! = lots of gas = made it run rich?
Petcock is NOT leaking = must be worn valve? or I've left it on.
Floats at 22mm.
Just to be sure,
the slides should have the bevel to "aft" ie air filter side?...................
Needle (stock) should be all the way up ie clip at the bottom?.................
10w40 MC oil is OK?...............
> > #42 and #135 jets and needle is #2423 clip in middle.
> > Air mix 1 1/8 out.
roadcapDen
2 HD XL's
65 Dream 305
Hahnda
Post by Hahnda » Thu Oct 13, 2011 8:45 am
Your float valve may not be working properly. Is it the original float needle or a replacement? Does that float have a leak in it?
roadcapDen
Post by roadcapDen » Thu Oct 13, 2011 8:51 am
Thanks,
All original and rubber etc looks good, no leaks.
Just to be sure,
roadcapDen
2 HD XL's
65 Dream 305
Hahnda
Post by Hahnda » Thu Oct 13, 2011 8:58 am
Yes bevels towards the filters. Your choice of oil won't really be a factor in getting it running.
Post by davomoto » Thu Oct 13, 2011 9:45 am
the slides should have the bevel to "aft" ie air filter side?................... YES
Needle (stock) should be all the way up ie clip at the bottom?................. SECOND NOTCH FROM BOTTOM
10w40 MC oil is OK?............... YES. I USE NON-SYNTHETIC FOR BREAK IN.
Adjust your floats like this link, and make sure they dont have fuel in them, remove and shake and listen.
Davo
http://www.honda305.com/upload/h305_for ... rb_214.jpg
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
