Frozen cam lock nut
Husker45
Frozen cam lock nut
Post by Husker45 » Fri Nov 18, 2011 3:20 pm
Just started restoration on a 1962 cb77. Motor was in a flood 40 years ago. Managed to get rockers removed after some effort, but cannot get the cam lock nut to break loose. Followed all advice on the forum, but to no avail. Any thoughts?
CliffC
Post by CliffC » Fri Nov 18, 2011 3:38 pm
First off if you didn't remember it has left hand treads. I would saturate the treads with PB Blaster each day until I was able to get it loose. Hope this helps, also could you include your location. Cliff
CliffC
Post by CliffC » Fri Nov 18, 2011 3:39 pm
Husker45
Post by Husker45 » Fri Nov 18, 2011 4:20 pm
I remember the left-hand threads, but to be sure that would be when looking from the point cam end correct? From that direction the nut would turn clockwise to loosen right?
48lesco
Post by 48lesco » Fri Nov 18, 2011 6:05 pm
+1 on the PB Blaster - make sure it's the penetrant, not the lubricant; and yes clockwise from the points cam end will loosen it. Wedge a piece of wood between the sprocket and the casting to hold it still, then I would shock it with a big screwdriver and dead-blow hammer on the nut. Don't use any heat because the advance weights have some rubber stoppers on them. You will eventually win...
rrietman
Post by rrietman » Fri Nov 18, 2011 10:01 pm
some of them, (the early ones) are right hand threads!
R
Re: Frozen cam lock nut
Post by LOUD MOUSE » Sat Nov 19, 2011 3:12 am
R is correct about the early ones being a normal thread.
If yours (1962) has the BIG WEIGHTS at the Center the thread will be normal.
I have had 4 of the usual looking ones that had normal threads so ya may want to try counter clockwise. . ............lm
Husker45 wrote:Just started restoration on a 1962 cb77. Motor was in a flood 40 years ago. Managed to get rockers removed after some effort, but cannot get the cam lock nut to break loose. Followed all advice on the forum, but to no avail. Any thoughts?
