Hi! Anyone know what is the factory piston clearance? I'm dropping at machine shop cylinders and pistons and they ask me what is clearance?
Please any help or links will be very helpful.
Thanks!
need pistons clearance
Re: need pistons clearance
Tell your machinist you won't .002 clearance measuring from the bottom of the piston skirt.
Make sure your sleeves are tight in the cylinder or you will never get proper heat transfer.
Good luck,
Tim
Good luck,
Tim
voxa_33 wrote:Hi! Anyone know what is the factory piston clearance? I'm dropping at machine shop cylinders and pistons and they ask me what is clearance?
Thanks!
