Rear Wheel Bearings
68Cb77
Rear Wheel Bearings
I've got 2 new bearings ready to go in the hub. One side is sealed, and the other side has the balls more exposed. When I took the old ones out, the sealed side was on the outside. Is that right? Thanks
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
82 Honda XR200R
70 Honda CB750 K0
Re: Seals
Grease in the void/spacer???????????. .........lm
ggray wrote:You're welcome. Just make sure you pack the bearings well and grease goes in the void between the inner and outer bearing..........Where the bearing spacer is.
Gary
