PDO::ERRMODE_EXCEPTION,
PDO::MYSQL_ATTR_INIT_COMMAND => "SET NAMES utf8mb4",
// newest completed CA entry (via view)
$sql = "
SELECT model_year, model,
ADM_StateOrProvince, ADM_Country,
condition_value, opinion_value_today
FROM h305_ca77_entries
ORDER BY submitdate DESC, id DESC
LIMIT 1
$row = $pdo->query($sql)->fetch(PDO::FETCH_ASSOC);
// casing helpers (same pattern as CB / CL)
$keepCaps = static function (string $w): bool {
return (bool)preg_match('/[A-Z]{2,}/', $w) || (bool)preg_match('/\d/', $w);
$word = static function (?string $w) use ($keepCaps): string {
if ($w === null || $w === '') return '';
if (strpos($w, '-') !== false) {
$parts = explode('-', $w);
foreach ($parts as &$x) {
$x = $keepCaps($x) ? $x : ucfirst(strtolower($x));
return implode('-', $parts);
if ($keepCaps($w)) return $w;
$dot = substr($w, -1) === '.';
$base = $dot ? substr($w, 0, -1) : $w;
$done = ucfirst(strtolower($base));
return $dot ? ($done . '.') : $done;
$title = static function (?string $s) use ($word): string {
if ($s === null) return '';
$s = trim($s);
if ($s === '') return '';
$t = preg_split('/\s+/', $s) ?: [];
foreach ($t as &$x) $x = $word($x);
return trim(implode(' ', $t), ", ");
if (!$row) {
$line = 'Latest Registry Entry: No completed entries found.';
} else {
// location like "WA, Australia"
$region = $title($row['ADM_StateOrProvince'] ?? '');
$country = $title($row['ADM_Country'] ?? '');
$loc = trim(
implode(', ', array_filter([$region, $country], fn($v) => $v !== '')),
// normalize opinion_value_today using the same rules as CL:
// - >=1000 => use as-is ($12500 => $12,500)
// - 100..999 => treat as dollars ($750 => $750)
// - 1..99 => treat as thousands (6 => $6,000)
// - otherwise => "Not Entered"
$valFinal = 'Not Entered';
if (isset($row['opinion_value_today']) && $row['opinion_value_today'] !== '') {
$n = (float)$row['opinion_value_today'];
if ($n >= 1000) {
$valFinal = '$' . number_format($n, 0);
} elseif ($n >= 100) {
} elseif ($n > 0) {
$valFinal = '$' . number_format($n * 1000, 0);
// condition code translation — same dictionary as CL plus "Rat"
$condRaw = $row['condition_value'] ?? '';
$condMap = [
'E' => 'Excellent',
'Exc' => 'Excellent',
'G' => 'Good',
'Goo' => 'Good',
'F' => 'Fair',
'P' => 'Poor',
'Par' => 'Parts Bike',
'R' => 'Restored',
'Res' => 'Restored',
'Rat' => 'Rat',
$condNice = $condMap[$condRaw] ?? ($condRaw !== '' ? $condRaw : 'Not Entered');
$line = 'Latest Registry Entry: '
. ($row['model_year'] ?? '') . ' Honda ' . ($row['model'] ?? '')
. ' — ' . $loc
. ' — Condition: ' . $condNice
. ' — Value: ' . $valFinal;
// stamp + UTF-8
$built = (new DateTime('now'))->format('Y-m-d H:i:s T');
$stamp = "";
$charset = '';
$html = $charset . "\n" . $stamp . "\n" . $line . "\n";
// write to shared include
$jobDir = __DIR__;
$includeDir = '/home/mstoic3/public_html/shared/include';
$includeTmp = $includeDir . '/latest_ca77.tmp';
$includeDst = $includeDir . '/latest_ca77.html';
$jsonPath = $jobDir . '/latest_ca77.json';
$logPath = $jobDir . '/logs/latest_ca77.log'; // future optional
if (!is_dir($includeDir)) {
if (!mkdir($includeDir, 0755, true) && !is_dir($includeDir)) {
throw new RuntimeException("Failed to create include dir: $includeDir");
if (file_put_contents($includeTmp, $html, LOCK_EX) === false) {
throw new RuntimeException('Failed to write temp include file');
if (!rename($includeTmp, $includeDst)) {
@unlink($includeTmp);
throw new RuntimeException('Failed to move include into place');
@file_put_contents($jsonPath, json_encode([
'line' => $line,
'stamp' => $built,
'ts' => date('c'),
], JSON_UNESCAPED_UNICODE));
echo "OK\n";
} catch (Throwable $e) {
error_log("[generate_latest_ca77.php] " . $e->getMessage());
if (function_exists('http_response_code')) {
@http_response_code(500);
echo "ERROR\n";
exit(1);
fab
Post
by fab » Fri Sep 30, 2005 7:54 am
Hi all,<br /> Two days ago I purchased a 1964 CA77 Dream . I'm very pleased with the bike as I was looking for something that could be rebuilt with out it costing to much money & this bike appears to be a very good basics for a cheaper type rebuild.<br />Anyway , The gear shaft spline has had it !! Can anyone tell me if it pulls out easy or does the Crank casing need to be split ???<br />I have not bought a manual yet , But I though one of you guys would be able to advise me on it .<br /><br />I have done the job before many years ago on a RM125.<br /><br />Also does anyone know if you can tell what colour a Dream was originally by it's frame number or any other means????????<br />I live in Australia & have not owned a bike for 10 years so I'm very keen to be playing with bikes again.<br /> Thanks Peter <br />
Pigeonalley
Post
by Pigeonalley » Fri Sep 30, 2005 11:00 am
Peter,<br /><br /> Welcome to the “Dream World” Great looking bike. Is there any reason you think the bike hasn’t always been black? Black was one of the four colors it was offered in. (blue, white, black, and red) I don’t think there is any way to know the original color except by a inspection of the frame and it’s nooks and crannies! <br /><br /> As to the shifter I’ll leave that to someone who has had to do this. I have only been into two left cases and both times it was to clean up the clutch and replace the shifter seal.<br /><br /> Again, welcome. If I can be of any help or you just want to talk Dreams Email me, my address is on my profile.<br /><br />Rob<br />
Old bikes like old men, sometimes you have to kick start them
Post
by LOUD MOUSE » Fri Sep 30, 2005 3:38 pm
Not a tough job but takes you removing several parts.<br />Remove the foot peg, shift lever, clutch cover, oil filter, (nows a good time to take it apart and clean it) 4 bolts in clutch face, all dics, "C" clip inside clutch, nut on crank shaft. sprockets and clutch housing, and now you can remove and replace the shift shaft and parts. I have good used ones here in the USA and I have shipped parts to Australia before. .....................LM
RIDE IT DON'T HIDE IT!
fab
Post
by fab » Fri Sep 30, 2005 5:54 pm
Rob, Thanks for the welcome. <br />No this bike was always black , But there's not a lot of dreams over here & you seldom see a dream that's not black . In fact I can only remember seeing a blue one once. I'm a bit of a stickler when it comes to being original . but I would have loved a coloured dream but I only ever found black ones & most were basket cases. I have noticed that it seems to be the opposite in the states " more red ones than black ones .<br /> / Peter
fab
Post
by fab » Fri Sep 30, 2005 6:10 pm
LM , That's great thanks .<br />I'll make a couple of calls though the week & see if I can find a new one , But I think that would be a tall order !! <br />If I have no luck , I would gladly buy a second-hand one off you .<br />How can I pay you ?? Pay Pal ? If I give you the Engine number will that help in matching the correct shaft ? I would also like a toe & heal gear lever. here's my email address .<br />
fab60s@bigpond.net.au <br /> Thanks for all you help & advice it's been a while since I played bikes & I have no contact for classic bikes . In fact I went to a Honda motorcycle shop to buy a Manual & they had never heard of a Honda dream !!! or a CA77 !! So I left shaking my head .<br /> /Peter
Pigeonalley
Post
by Pigeonalley » Sat Oct 01, 2005 12:00 am
Peter<br /> Don’t expect much help out of any Honda dealership. Their computers don’t go back but 15 or 20 years. Here in the States most of the people on the counters aren’t much older then that themselves. Your best bet is to go in with the part number to begin with, do not expect them to find it for you. They can’t. If you have the part number they can find it that way. But if you have the part number most any bike dealership can get the part for you. <br /><br /> I live is a small North Texas town the Honda shop charges me 10% over Suggested retail for my parts but the Suzuki shop sells the same parts at retail. The Honda shop has made it clear they don’t want my business. They tried to fail my Dreams first State Inspection because it didn’t have turn signals. They knew better! What they didn’t know was that I knew better! They can not make you “retro fit” a vehicle! I went through that with my old Ford with only a left tail light. <br />Anyway good luck we are all here for you.
fab
Post
by fab » Mon Oct 03, 2005 4:23 am
The guy at the Honda shop was only a young fella about 20 but it did me feel like a Dinosaur !! Away I just wanted to drop a quick note to say Thanks for your help with the parts , Though this Great Web site I have made some contacts & my parts will soon be here . ............. Thanks Peter
