Very ignorant on carb adjustment....
brewsky
Post by brewsky » Tue Sep 21, 2010 11:40 am
You mean the needle that is attached to the slide that is attached to the cable?
Compress the spring till you get enough slack in the cable to unhook it from the slide.
Be prepared to go look for the spring after it goes flying across the garage.
There is a large clip in the top of the slide that holds the needle in.
The needle has a small clip and 5 grooves to select from which determines the fuel mixture mid range. The lower the clip, the richer the mixture..should probably be set in the middle groove to start.
Loudo
One thing at a time
Post by Loudo » Wed Sep 22, 2010 2:05 pm
Because of the way these carbs work, you can have a problem that presents itself at speed even though it idles fine. This is due to the different route the fuel takes depending on throttle position. If it's idling fine, messing with the air screw and slide screw won't address the problem you're describing which seems to be at intermediate to full throttle...? You've described an engine running rich, the first step might be to lower the jet needle one notch and see if that helps. You also might check the main jet again to make sure it's the stock size.
sky1haze
Post by sky1haze » Wed Sep 22, 2010 2:17 pm
What exactly is the stock size?????120?
-joel-
_______________________________________
1966 CA77
Loudo
Post by Loudo » Wed Sep 22, 2010 3:30 pm
Main jet 135
Slow jet 42
sky1haze
Post by sky1haze » Wed Sep 22, 2010 4:28 pm
Thanks Loudo, Now this is for a 1966 dream????
-joel-
1966 CA77
Loudo
sorry
Post by Loudo » Wed Sep 22, 2010 4:32 pm
I have a CB77....I didn't know it was a Dream we were talking about, somebody else will have to answer your question.
sky1haze
Post by sky1haze » Wed Sep 22, 2010 4:40 pm
Very good sir! I do appreciate your quick response!
-joel-
1966 CA77
