Inner fork seal replacement??
nkarshna
Post by nkarshna » Thu Aug 17, 2006 11:05 pm
Hi everyone. I'm trying to replace the inner fork seals in my father's 1967 305 scrambler and I can't get the friggin things out. I took off the clip under the piston and I thought the piston would slide off. Guess not! Can some one out there give me some advise in how to do this. Thanks
Re: Inner fork seal replacement??
Post by LOUD MOUSE » Fri Aug 18, 2006 7:01 am
That part is supposed to be loose and rotate on the tube. Tap on it to get it off the end. I remove the steel seal keeper at the top first and then pull down Quick and Hard and the parts at the bottom of the tube will pop the seal out of the slider. .........lm[
quote="nkarshna"]Hi everyone. I'm trying to replace the inner fork seals in my father's 1967 305 scrambler and I can't get the friggin things out. I took off the clip under the piston and I thought the piston would slide off. Guess not! Can some one out there give me some advise in how to do this. Thanks[/quote]
kustommusic
Post by kustommusic » Fri Aug 18, 2006 6:07 pm
Ed, Does that work the same for the CB forks? Steve Greer
Post by LOUD MOUSE » Fri Aug 18, 2006 8:54 pm
Depending on the sliders. The steel ones have the seal in the removable chrome part.
Now I must admit that tis been some time since I've done one of the aluminum slider CB72/77 forks but I "think" (NOT SURE ) that it may be the same. .........................lm
kustommusic wrote:Ed, Does that work the same for the CB forks? Steve Greer
nkarshna
Post by nkarshna » Fri Aug 18, 2006 11:28 pm
I can't get this thing to budge! What would you guys recommend?
Post by LOUD MOUSE » Sat Aug 19, 2006 8:05 am
Beat it off and I'll sell ya another one. ............lm[
quote="nkarshna"]I can't get this thing to budge! What would you guys recommend?[/quote]
