Stiff Clutch
56_oval
Stiff Clutch
Post by 56_oval » Fri Feb 25, 2011 3:39 pm
Ok, so I finally got her close to roadworthy, but I'm having issues with the clutch. I have to use both hands to pull it in. I've never been on a cb77, so I don't know for sure, but this cant be right. Is there something that I should look for to fix this?
cyclon36
Post by cyclon36 » Fri Feb 25, 2011 4:01 pm
Definitely doesn't sound right. Your clutch cable isn't looped or bent in any area is it? Does it have resistance in the release as well or is it just hard to depress? Is your cable new or used? If it's used, have you tried lubing the inside at all?
56_oval
Post by 56_oval » Fri Feb 25, 2011 4:57 pm
cyclon36 wrote:Definitely doesn't sound right. Your clutch cable isn't looped or bent in any area is it? Does it have resistance in the release as well or is it just hard to depress? Is your cable new or used? If it's used, have you tried lubing the inside at all?
Brand new and lubed. I read spargetts post about the same thing and I think it's the cable length. I think it may be too short. Is it just like the front brake cable? I wonder if I mixed em up.
Snakeoil
Post by Snakeoil » Fri Feb 25, 2011 6:26 pm
The arm on the clutch release mechanism should be below 90 degrees to horizontal so you actually pull it thru 90 to slightly past it. If the cable is too short, the arm will be much closer to vertical. This does two things. First, it greatly reduces the mechanical advantage and second sets you up to run out of travel in that you will be pulling straight up on the arm with the arm at 12 o'clock. You are basically trying to stretch it.
Pull off the side cover and have a look at the arm. That will tell you if the cable is too short or not.
regards,
Rob
56_oval
Post by 56_oval » Fri Feb 25, 2011 7:15 pm
Snakeoil wrote:The arm on the clutch release mechanism should be below 90 degrees to horizontal so you actually pull it thru 90 to slightly past it. If the cable is too short, the arm will be much closer to vertical. This does two things. First, it greatly reduces the mechanical advantage and second sets you up to run out of travel in that you will be pulling straight up on the arm with the arm at 12 o'clock. You are basically trying to stretch it.
regards,
Rob
I looked at it earlier and it seems to be what you are describing. I don't think the cable is long enough, but it's the same one they sell on olypen.com. 34.75 inches. I'm using Tomaselli levers though, but I think their placement is close to stock.
I'll check again when I get home.
mike1969
clutch
Post by mike1969 » Fri Feb 25, 2011 7:25 pm
Had the same trouble with my Dream. I removed and dis assembled the clutch lifter and thoroughly lubed all moving parts. Now it's smooth as butter.
GeorgeP1111
Post by GeorgeP1111 » Sat Feb 26, 2011 8:06 am
56_oval wrote:I don't think the cable is long enough, but it's the same one they sell on olypen.com. 34.75 inches.
FWIW: Last year I bought a Throttle cable for my CA77 from them and the cable housing was 1/4" longer than the one that was currently in use, but the inner "Pull" cable was the same length. End result was that the carb slide was held up (unable to bottom out) even with all adjustments set to mininum.
George
