Fiber Discs?
cleg
Fiber Discs?
Post by cleg » Sat Sep 10, 2011 8:35 am
I took my clutch apart as it was slipping. Everything seems to be in great shape other than the these seem to be the crappy fiber discs. After replacing with the good ones, is there a particular way that the steels should be placed (They have notches around the inner edge.)?
'66 CB77 '75 Rd125
Post by davomoto » Sat Sep 10, 2011 10:57 am
Cleg,
The thick steel goes in first. I stagger the notches in the steel plates.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Re: Fiber Discs?
Post by LOUD MOUSE » Sat Sep 10, 2011 11:22 am
I hope ya didn't replace with the fiber plates.
Makes no difference where ya index the steel plates as the slots are to keep the plates from warping from heat. ...........lm
cleg wrote:I took my clutch apart as it was slipping. Everything seems to be in great shape other than the these seem to be the crappy fiber discs. After replacing with the good ones, is there a particular way that the steels should be placed (They have notches around the inner edge.)?
cleg
Post by cleg » Sat Sep 10, 2011 12:13 pm
Thanks guys, I just took the clutch apart last night. I still need to obtain the correct frictions. My springs are measuring 33mm, I guess they are good to go?
'66 CB77 '75 Rd125
OldStan
Post by OldStan » Mon Sep 12, 2011 10:19 am
Here's a link to a discussion on clutch springs, and lm's recommendation;
http://www.honda305.com/forums/viewtopi ... h&start=10
You might check the wire diameter, but from the length it looks like you have the best ones.
63 CA78
