CL77 Fuel Line connection to Carb
sibes67
Post by sibes67 » Thu Sep 25, 2014 7:50 pm
All good on the 66 scrambler except for this: the right side carb's fuel line connection seems to have a tiny seepage of gas. Am talking about the vertical line as it connects to carb. I had a small hose clamp there, and could see a drip of gas on the tightening screw head. So took that off, thought it might be too tight, and replaced with proper expansion ring. Still gas seeps out, down fuel line, onto engine cover. So, could it be the components on exterior of carb, with those 2 inner gaskets? I have a diagram of the carb but don't have part numbers for that fuel input flange nipple or whatever it is called. Any help appreciated. Thanks.
Sibes67
Geeky160
Post by Geeky160 » Thu Sep 25, 2014 8:34 pm
'67 CL77 (337, gears X'd)
'65 CB160
sibes67
Banjo Washers Prob Solved
Post by sibes67 » Fri Sep 26, 2014 7:32 pm
Thanks Geeky, those would have been correct. I wanted to fix ASAP instead of ordering online, so stopped at local Honda shop. Got a couple of these: 90545-300-000.
On order slip they are called "oil bolt washers", at $2.75 each. I installed and gas seepage is gone. These are not felt, but metal---so I will watch to insure they keep working to seal that banjo bolt to the carb. Counter guy said they are used to seal brake calipers.
Sibes67
