Electronic Ignition is Back !!!
minis2003
Post by minis2003 » Thu Sep 12, 2013 12:56 am
anyone recently installed electronic ignition on a 305 dream??
Carl
Re: Electronic Ignition is Back !!!
Post by Carl » Fri Nov 07, 2014 9:42 pm
Michael Stoic wrote:
This is a pre-announcement. Starting now, the Electronic Ignitions are once again available.
There will be a limited quantity of the new version of the Electronic Ignition Kits for all CB/CL 72/77 motors.
If you've been hoping to get one, please contact me by email. I will send out full details within the next few days, by email.
Thank you,
Michael Stoic
honda305.com
Michael, is this unit still available? I have tried other means of contacting you but maybe this will work. Lol. I have a 67 CL77.
WrenchRust
Post by WrenchRust » Sat Aug 15, 2015 7:06 pm
I've also emailed him without response. I'm going to assume that they are no longer available. Not sure why this thread is still sticky'ed
Peter Handscope
ignition key
Post by Peter Handscope » Fri Dec 21, 2018 11:38 am
If you find yourself in a situation where your key won’t turn in the ignition of your vehicle, there are a number of issues that may be causing the problem. If the ignition cylinder has seized, spraying a small amount of electrical cleaner into the key hole may lubricate it enough to turn. Be careful not to spray too much into the key hole. A few short squirts should sufficient.
