Wanted: CB 72/77 front hub
I would like to find a good used front hub, complete with brake plate, from a CB 72/77. I don't need the rim or tire, but if they come with the hub, that's fine. I'm in northern CA, please call or email. 650-572-8282, biomedpub@yahoo.com --Randall
Front hub
Do you have the steel sliders, or the aluminum ones? The brake plate is different. DO you need speedo drive as well? Reverse needle speedo, or regular? I am in the bay area, and may have what you need.
Re: Front hub
Checking my fiche I don't see a difference for the hub or the backing plate no matter the steel or aluminum sliders. Am I wrong?. ...........................emo
quote="davomoto"]Do you have the steel sliders, or the aluminum ones? The brake plate is different. DO you need speedo drive as well? Reverse needle speedo, or regular? I am in the bay area, and may have what you need.
davomoto[/quote]
davomoto[/quote]
