Interesting, what does the label on your wiring harness say ? (there you can find the year of manufacturing). Do you happen to have any pictures of the bike ?, especially of the winkers, and how these are attached ?
(By the way thanks for posting, I see you're a member for a longer period, and this is your second post, keep up the postings).
CB72
Thanks guys for the info i suspected the 6 digit motor was 1964 i was told it could be 1961 thats why i asked in the first place. at the moment i am rebuilding this motor which will then be reinstalled into the frame and hopefully it will run ok, the crank has been lightened and ballanced, rods polished, cylinders have been bored to 64mm and fitted with asso 64mm race pistons, 1mm oversize stainless steel valves, ports have been flowed, 30mm amal concentric carbs, read titan cams. i did use to race this bike in the 80's it was last used around 96 by my son then it has just been gathering dust in the garage so nows the time to sort it.
Dave
Dave
honda brian
