removing rocker arm pins
Post by LOUD MOUSE » Thu Aug 12, 2010 6:02 pm
Right there teazer.
Ya know what to Just Look at and know which is which without a Mic?. ............lm
teazer wrote:The key is that intake pins and exhaust pins have 0.5mm difference in diameter IIRC.
Where the rocker arms ride is the same, but where they go into the head is different. On engines that have been torn down a few times the holes often end up slightly oversized from fitting the wrong pins.
teazer
Post by teazer » Fri Aug 13, 2010 12:47 am
No LM.
I just measure them. There's an easier way?
Post by LOUD MOUSE » Fri Aug 13, 2010 9:50 am
Look at the size of the oil hole in the middle.
Ya will see 2 sizes.
The larger is the intake and the smaller is the exhaust. ......................lm
teazer wrote:No LM.
teazer
Post by teazer » Fri Aug 13, 2010 10:11 am
After all these years, i still learn something new every day. Thanks.
Post by LOUD MOUSE » Fri Aug 13, 2010 10:41 am
For years I would put them end to end and one day I noticed the difference at the holes and that made things easier/quicker. ........lm
teazer wrote:After all these years, i still learn something new every day. Thanks.
pc13cb92
rocker shafts
Post by pc13cb92 » Fri Aug 13, 2010 3:37 pm
Hi, just joined forum. Been looking for this info on the valve rocker shafts, as I have just taken my spare C72 motor to pieces in order to do a check and rebuild. I took out the shafts whithout realising they were different!
This spare motor was in a right mess - someone who did have a clue had had it to pieces before I bought it, and totally butchered it.
c72
c92
cb92
Post by LOUD MOUSE » Fri Aug 13, 2010 5:37 pm
I recommend ya put the left side parts on the right and vice versa. .......lm
houseowax wrote:Well, I 'bagged and tagged' each one. I hope that's enough. I TRY to pay as much attention to a part's location and special features etc when I'm dismantling, but sometimes I get too caught up in the act and my attention to detail suffers. There's a learning curve here, that's for sure, but I'm getting better all the time. At least...I hope I am.
